this may be a really dumb question but computers and I don't get along. I looked on linearteam.com but couldn't really find an answer.
Does Winisd work with windows vista? i downloaded it and tried to install it which it seems to do but will not run the program.
Help...please
I have run the alpha version on vista. If you go to programs to start it but then right click to properties and go to the compatibility tab....try some of those it may help. Note that I can't close it down even though it works fine, I have to axe it with prog manager.
Read the post here on it, you only put some of the TS specs in and it calculates the others. That seems to be the most common problem for new users. If it calculates and your number is rounded off like they often are it gets mad at you.
I will give it a try and report back. thank you
