Is this something that’s actually possible? I don’t mean oxidation either. I am meaning wire sitting inside its silicon surround? I am more curious to how this is possible and why and is there facts to prove this if this is a real thing?
I assume that the lack of a smiley face, is a sign that oxygen oxidises?…
... If the copper truly is OFC it will take FOREVER to oxidize because there's no oxygen in it to oxidize.
That's just OFC. You could buy welding cable and save a TON of money. I also don't like that Knu uses grossly oversized cable making fitting a pain sometimesI meant to reference aluminum wire. Like the kind that was used in homes in the past. Still is used in homes?
I have a hunting trailer that is a mobile home from from the 70s. The supply line is all aluminum I believe.
Makes the bill higher and house run less efficiently is what the guy that put the new box in said.
Nothing has been changed or updated at all. I'm not sure if aluminum can be used in tinning.
I'm not sure what all metals are used at all really.
But I do know that knukonceptz makes wire that will easily out last the vehicle. In any conditions.
It is the only wire I will buy from now on.
Maybe an equivalent if they go out of biz.
RoHSDid you know.....
The world as we know it was saved in 2006 when lead was banned from solder.
Think about a world where every phone you hold is laced with lead.
We would all be retards in like 20 years from the heavy metal build up.
