I am currently running a single 4x75w amp, and so just using 8 gauge power/ground wire. Since I am starting to piece together everything I need to redo my system, I think I am going to need larger power/ground wires.
Eventually I will be running an additional amp, somewhere between 4x60w and 4x100w, along with an MS8. So figure on 700W from my amps.
Would upgrading my power/ground wires to 4 gauge be OK for this? Also, I am looking at distribution blocks, assuming I need one for both the power and the ground wire. I found one that is 4 gauge in and 4 x 8 gauge coming out. Would that work for my plans?
Anywhere better price/options than knuconceptz?
Thanks.
4 gauge is a real 3 from KNU and check to see if your amps can handle 4 gauge as this would be best.
Yup. That should be fine.
Knu is OK for the money.
Just OK?
Where do you get yours from?
Only thing I don't like about Knu is that they ship via USPS. I could probably build my own wire factory before their stuff is delivered.
