ok well if any of you have seen my previous thread
http://www.diymobileaudio.com/forum/product-selection-comparisons/56052-crystal-clear-hammering.html
i did get the dayton MKIII subs. well i hooked them both up inside my overly huge sealed enclouser..i have them hooked to a kenwood excelon x1200m..1200rms...there hooked up in parallel @ 2 ohms..
anyways i started rockin to a creed song and my dad begged for bass so i through my bass test cd in...about 10 seconds into it they stop
first time out with new subs look what happens....
its 60Amps if you cant read...
now i think my fuse is too small but a short is possible so i am going to check...but just to be sure i want your guys advice
if you want to know i have my subs hooked up like this....
i ran 1 set of wires to the + and + side of one woofer....then SODDERED another set of wires to that.....the soddered end of the pair of wires i conected to the other woffer....then the other to the amp
so basicaly one + on one woffer is hooked up to the other woffer...then another wire is hoked up to that woofer (the one with the wire from the other sub) to the amp.......the negative is the same
did i do somthing bad/wrong?
is the fuse to small?
in case you havent noticed those are pictures of my amp and subs
edit: my power cable is 4gauge (i got jipped on it it isnt as thick as it should be but its bigger than six gauge so really close to 4 gauge) its about 2 inches from my battery before the fuse..then it runs about 14-16ft to the end of my car to the amp
