Hi,
Hopefully a very quick question...
This is pretty much exactly the setup I need in order to present my amp with two 4 Ohm loads from the subs.
My question is whether the (green) bridge wire could be run between the two outer-most terminals on the subs (pos-neg), and then the speaker wires can run to the inner-most terminals.
My motivation is purely aesthetic - the sub enclosure I have built has a window at the rear and it would be nice if the speaker wires were a little neater by connecting to adjacent terminals.
Many thanks.
It will work either way. You can always use a DMM to measure the resistance before hooking it up to the amp to ensure you have it wired correctly.
