Hi there. I have just purchased a sub and an amplifier and I have a wiring question. The sub is DVC (2 2ohm coils). I know I want to wire in parallel for 1 ohm output. My question is as follows:
Would it be better to simply wire the sub in parallel on the sub terminals themselves (positive to positive, negative to negative), OR mount two sets of speaker terminals from the cabinet (one for each voice coil) and two sets of wires (again one for each voice coil) and them wire them to the four terminals on the output section of the amp? (attached is a picture from the manual showing hooking up two subs, and instead of that I would be hooking up each voice coil individually). Basically is it better to do the "parallel" part on the sub, or "in" the amp. I would think individually wiring the voice coils would be twice as much wire if nothing else so might be a better signal? This might be insignificant or it might not be. Thanks!
