1 - 5 of 5 Posts
Hi, I'm looking into buying two Sundown Audio SA-10s to wire into my Alpine PDX-1.600 Mono Amplifier. I was wondering whether to buy the sub-woofers with the Dual 4 ohm coils or the Dual 2 ohm coils. Also I wasn't quite sure how to do the wiring..
The sub-woofer enclosure I have that I received from my cousin has wire running from the outside into one of the boxes, and then a wire between the first and second box.. Is this okay or do i need to run the wire from the second box outside of the box as well? (If this isn't clear enough I apologize and can provide pictures.)
Here are links to both the Amplifier and Subwoofers:
SA-10's: SSA Store - Sundown Audio SA-10 Subwoofer
Alpine Amp: Alpine PDX-1.600 Mono subwoofer car amplifier 600 watts RMS x 1 at Crutchfield Signature
Thanks for any help,
Pete
Discussion Starter #2
you need the dual twos with the plan to wire the two together to show the amp a two ohm load
sorry posted before i looked at your diagrams the second one is how you want to do it to get the most out of the amp you have
you can get either configuration and it will work. the pdx series produce the same power at 2 or 4 ohm.
1 - 5 of 5 Posts
