1 - 5 of 5 Posts
I am working on a E36 BMW using stock speaker placement. I am using a pair of PG ti elite subs, legatia L6 in kicks, L3's and L1proR2's in the doors. I also have a MS-8. I will either use all ZPA amps or all xenon amps. The amps I have available to use are (5) ZPA 0.5's and (2) ZPA 0.3's. For the xenons i have (2) 1200.1's, (1) 200.4, (2) 200.2's, (2) 100.2's, and a 100.4.
My ZPA idea is
1 0.5 to each sub
1 0.5 to L6's
1 0.3 to L3's
1 0.3 to L1's
Xenon idea
1 1200.1 to each sub
1 200.4 bridged to L6's is this to much power?
1 200.2 to L3's again maybe to much power?
1 100.2 to L1's
should I only run a 200.2 to th L6's and a 100.2 to the L3's?
any input would be appreciated
get amps that put out twice the power your speakers are rated for, this will allow you to drive each speaker cleanly , which will improve the sound quality.
Do Not get an amp that will allow you to clip it in the hopes that you get every last ounce of power out of it.
So, if I follow that way of thinking i would use the 200.4 bridged on the L6's and 200.2 on the L3's. Should I also run a 200.2 on the L1's? I have it available
too many damn numbers for products and whatnot, just use Oli's suggestion.
1 - 5 of 5 Posts
