Would someone please help me spec out some new subwoofers for my Coustic BassPumps? Since OEM is no longer available, I would like to upgrade to the best subs that I can for these things.
Coustic DR-306 Subwoofers (supposedly designed by Rich Coe 1990 era) installed in a Coustic BassPump DR-326. I own 2 of these.
Sensitivity 1w/1m: 88db
Frequency Response -3db: 32hz-2000hz
XMax +/-: 4mm
Fs(Hz): 26.4
Vas: 26.3
Qts: 0.24
Qes: 0.27
Qem: 2.49
Sd (Sq CM): 125
Le (mH) 0.98
Re (ohms) 3.6
Input Impedance: 4 ohms
2nd Subwoofers Coustic DR-308 Subwoofers (supposedly designed by Rich Coe 1990 era) installed in a Coustic BassPump DR-328. I own 1 of these.
Sensitivity 1w/1m: 89db
Frequency Response -3db: 25hz-2000hz
XMax +/-: 4mm
Fs(Hz): 25
Vas: 57.5
Qts: 0.26
Qes: 0.28
Qem: 3.55
Sd (Sq CM): 220
Le (mH) 1.28
Re (ohms) 3.5
Manual for the Bass Pumps: Coustic DR-326 user manual - ManualsBase.com - Solve your problem
XMax +/-: 4mm
Fs(Hz): 26.4
Vas: 26.3
Qts: 0.24
Qes: 0.27
Qem: 2.49
Sd (Sq CM): 125
Le (mH) 0.98
Re (ohms) 3.6
XMax +/-: 4mm
Fs(Hz): 25
Vas: 57.5
Qts: 0.26
Qes: 0.28
Qem: 3.55
Sd (Sq CM): 220
Le (mH) 1.28
Re (ohms) 3.5
