1 - 7 of 7 Posts
If you're comfortable with 10" drivers, I have an pair of the excellent Exodus Audio DPL-10, which are also optimized for IB use, also have a clean low inductance motor, lots of throw, and a low Fs. I'm in Los Angeles, if you're nearby we can skip shipping too.
Here are the T/S parameters:
Fs: 23 Hz
Re: 6.5 Ohms
Qms: 4.7
Qes: .91
Qts: 0.76
Mms: 99g
Cms: 0.47 mm/N
Vas: 73L
Sd: 333 cm^2
Vd: 1.26L
BL: 10.2
X-max: 13mm
Pmax: 300W
SPL: 81.7 db/1W/1M
Attaching a picture, and here's a build thread of a guy who used these for a pretty high-end home build.
$75 for the pair if bought locally.
Cheers,
Tal
Fs: 23 Hz
Re: 6.5 Ohms
Qms: 4.7
Qes: .91
Qts: 0.76
Mms: 99g
Cms: 0.47 mm/N
Vas: 73L
Sd: 333 cm^2
Vd: 1.26L
BL: 10.2
X-max: 13mm
Pmax: 300W
SPL: 81.7 db/1W/1M
Cheers,
Tal
They look nice, but I’m set on 12’s
1 - 7 of 7 Posts
