What's your budget including shipping? I may have a line on one.up up up
how much u want for it? on ebay it usually goes for around 140..What's your budget including shipping? I may have a line on one.
i need the t/a, eq, and 3 way xover.. sorryI have a 9853, good condition, no remote or trim ring $125 shipped.
Checking with my buddy to make sure he has everything for it.... let you know when I find out.how much u want for it? on ebay it usually goes for around 140..
I just checked and the 53 most certainly does have bass engine pro.i believe the 953 do not have t/a or 3 way cross over.... ok macxx, just let me know and some pics would be nice..
thank you
ooooo what is the difference between the two units then?I just checked and the 53 most certainly does have bass engine pro.
why is that?I have a 9855, if I had it to do over I would get a 9835 for
a few more dollars.
The 9853 does not have the biolite display, which honestly I'd try both with polarized sunglasses on because the biolite blows in that area. I believe the 53 MAY have a lower preout voltage but honestly I don't see how it could be much lower than that of the 9855, I think the 9855 raises it's preout voltage with a stickerooooo what is the difference between the two units then?
thanks for the info!The 9853 does not have the biolite display, which honestly I'd try both with polarized sunglasses on because the biolite blows in that area. I believe the 53 MAY have a lower preout voltage but honestly I don't see how it could be much lower than that of the 9855, I think the 9855 raises it's preout voltage with a stickerAND I think you can't disable the display "bling" on the 53 whereas you can on the 55, which was a MAJOR selling point for me.
You are gonna like iPersonalize too![]()
These are just my impressions of my 9855why is that?
thank you for your opinion.... u got me thinking... maybe i need to start a new thread.. WTB 9835. thank youThese are just my impressions of my 9855
Glide touch blah. Although I have not actually measured it, I have a hard time
believing my 9855 really puts out 4v because I have had other older Alpine 4v
head units that seemed to have a higher quality signal. Also, I feel mine clips a
little early in the volume level (mid 20's of 35). The sub out seems to have a
volume control scheme with 2 settings, "all out way to much" and "nearly
impossible to blend with need for readjustment on every new song". I have the
internal amp off yet the unit get's warm under heavy play.
Maybe mine is a lemon.
Agreed on the aboveThese are just my impressions of my 9855
It actually will not clip, so much in fact that any "click" of boost put on the EQ will peel that number off of the master volume. So if you boost, say even 20K by 2 "clicks" you volume control will stop increasing at 33 of 35, 34 and 35 are the same as 33. Is this what you are possibly noticing? The lack of gain after a certain point? have any radical EQ boosts?Also, I feel mine clips a
The first sub level style setting does not decrease the sub at a linear level and it's allowed to play louder when the volume is down, it's the gayest form of "loudness" ever. The second setting has linear attenuation and if you have your gains set properly it will be fine, Yes, I have to adjust my sub level because no, the beatles will not romp like Flo-Rida. If you have it set at the linear setting and you are constantly adjusting the sub level then you would be doing the same thing with any headunit.The sub out seems to have a
Mine does not get HOT under play but will get warm, it's perfectly normal, it's called packing a PS, Laser assembly, lots of motors and a few DSP engines in a tiny box. You think that gets hot you should feel a CD after it comes out of a DSP enabled Eclipse!I have the
Thanks for the explanations!Agreed on the above
