1 - 2 of 2 Posts
Power Handling: 700 watts RMS
Sensitivity: 94.2db (2.83 volts)
Impedance: 4 Ohms (SVC)
Outside Diameter: 46cm (18 1/8")
Mounting Diameter: 41.9cm (16 1/2"")
Depth: 20.3cm (8")
T/S Parameters - MJ-18M - 4 Ohms
Fs = 24 Hz
Re = 3.6 Ohms
Qes = 0.37
Qms = 5.59
Qts = 0.36
Mms = 316.6 grams
Rms = 8.5 kg/s
Cms = 0.14 mm/N
VAS = 210 litres
Sd = 1029.2 cm2
Xmax = 15 mm
Cone Diameter = 36.20 cm
Recommended Box Sizes:
Sealed: 93 litres (3.3 cu. ft.)
Ported: 142 litres (5 cu. ft.) 30Hz tuning
EBS: 283 litres (10 cu. ft.) 18Hz tuning
Anyone got an amp that would be good for this sub, or recommend one? The cheaper the better. Maximum price of $200.
1 - 2 of 2 Posts
