Not sure I can talk Mario ( @quickaudi07 ) out of his. Just feeling things out for a possible change.
I highly doubt he’s ever giving them up! In fact he’s probably filling his closet with whatever comes up for sale as backups. Might have to grow another set of 🥜Not sure I can talk Mario ( @quickaudi07 ) out of his. Just feeling things out for a possible change.
Using an AS 200.2 for mid bass duty. Putting them in kicks. You still have your Jeep?Probably take a buddy looking out for you to find a pair of these! How many watts would you want to run on any of the aforementioned midbass drivers?
Haven’t listened to either of these..doing a little research on both now. Have a buddy that’s trying to sell me a set of AD sw800 but he didnt have them hooked up for demo so on the fence on those until I can hear them.While they are good, there are other good options out there. If you don't want to spend with your left nut, look into the Illusion Carbon 8's, or BLAM Signature 8's.
I’m currently running the phase plug version. I like them just wanting a change and a little more kick. I have no real life experience with comparison but everyone that ive talked to that run zr800s say there is no comparisonHybrid Audio L8SE-Dustcap how would these stack up against the ZR800’s.
I would go with audio development W800neo insteadWhile they are good, there are other good options out there. If you don't want to spend with your left nut, look into the Illusion Carbon 8's, or BLAM Signature 8's.
I don't think you could compare these 2. Hybrid vs JL zr800.. hell no!Hybrid Audio L8SE-Dustcap how would these stack up against the ZR800’s.
I’m running IB kicks that vent into the unibodyFocal 8wm has a QTS of 0.9 and 5.5mm of xmax.... not saying it will have as much low end punch as the zr800 but i believe it has excellent specs for an IB door install.
Even better. Hybrids are high sensitivity drivers with not so much excursion.. thats just how they are.. nothing wrong, its just a different type of design. Usually very low distortion, but they have less excursion.. you must have a good sub well blended with your front stage.. speaker design is always a tradeoff you will never find a 95db midbass with 10mm of linear excursion.. it just does not exist..I’m running IB kicks that vent into the unibody
What do you think about the audio development sw800?Even better. Hybrids are high sensitivity drivers with not so much excursion.. thats just how they are.. nothing wrong, its just a different type of design. Usually very low distortion, but they have less excursion.. you must have a good sub well blended with your front stage.. speaker design is always a tradeoff you will never find a 95db midbass with 10mm of linear excursion.. it just does not exist..
With that said, all you might need is a 8" with a little bit more throw and i bet you can get the midbass up quite a bit in comparison to the hybrids..
Have you seen Erins review? I've only owned the W600 but they are good drivers...What do you think about the audio development sw800?
