1 - 2 of 2 Posts
Looking for the 4 Channel Metered amps, 400W preferably.
Will consider a 4 channel 400w non metered amp.
HU's with the dual DACs
Changer to match up with the HU
Equalizer controllers for the equalizers (this is going to be hard to find)
Equalizers
as good condition as possible. Sending stuff in to McIntosh to repair/replace parts is absurdly expensive.
Varied I would assume based on condition of the item etc..
Pack it well, they get damaged!
I check ebay a lot, so thanks in advance if you plan on telling me "check ebay" :)
If you have something but the cosmetic condition isn't all that great, still feel free to contact me. We can try and work out something depending on whatcha got and what you want for it.
Discussion Starter #2
Also, not sure if its relevant. But I'm planning on running 200w to each mid. I'll have two pairs of mids and highs. Most likely I wont be running the tweets separate.
So I was thinking bridging a couple of the 4 channel McIntosh amps to power this setup. Then I'll go get a functional amp for my 2 8's/sub. I don't see much pt in spending a ton of cash on a SQ amp to run subs, seems backwards to me. :p
1 - 2 of 2 Posts
