1 - 8 of 8 Posts
Good amplifier for subwoofer, SQ oriented amplifier please. Must be at least 1k @ 2 ohm, preferably between 1k-2k @ 2 ohm.
Smaller footprint preferred, but not required. Preferably up to ~20" length.
2 channel amp that bridgable at 2 ohm is an option too.
Have to work perfectly, cosmetic is secondary.
Used preferred.
Closer to $300ish, willing to spend extra for the right amp.
Negotiable
I know it's not quite the power your looking for but I have a Sundown SAZ-1200d. I'm in Renton too so we wouldn't have to ship it.
If this doesn't work ^^^. There are two people on here with zapco 9.0 amps a little above your price range that would be brutal in achieving your desired requirements. And I'm in the south sound too, but don't wanna sell my 9.0 :)
Rated at 2200w into 2 ohms, universally agreed to be under rated
Price when new was around $2,500, can be had now > $500-800
60%+ efficient, so an easier load on your electrical system
If your system is complete enough and you want to do the legwork, I might be convinced to let you hook mine up and see for yourself....
Thanks, I will pass on that one.
I actually just buy one of 9.0. I plan to use it for my midbass. I don't think I can afford two 9.0 (especially I can't justify spending that much for subwoofer amplifier).
I would suggest you try the 9.0 on sub and play around with something else on midbass.... just sayin!
If you have it, give it a shot.
Looks like the mmats is class a/b. I would absolutely run that on the midbass and the 9.0 on the sub
I have mcintosh powering tweeter, which i kind of set on that one.
I also have xdi 1200.6. Not sure which are the best amp setup to use and which to sell.
1 - 8 of 8 Posts
