1 - 12 of 12 Posts
I have DLS CA-51 used that I want to part with. Will do what you want I think. Mine is in black, the new ones are silver. Also have a pair of DUR1 DLS tweeter that you can power directly from this amp with no external crossover as you can do with woofers.
Specs:
Number of channels 5
Amplifier class AB
Output power in 4 ohm 4 x 50 W
Output power in 2 ohm 4 x 80 W
Mono bridge mode 4 ohm 2 x 150 W
Mono sub channel 4 ohm 170 W
Mono sub channel 2 ohm 225 W
Damping factor > 100
S/N ratio, A-weighted > 100 dB
Frequency range 10 Hz - 35 kHz
Input sensitivity 0,25 - 5 V
Input impedance > 10 kohm
Input impedance, high level 100 ohm
Filters channel A & B HP: 15-500 Hz. LP: 50-500 Hz / 05 - 5 kHz (x10)
Low level output No
Filters channel C & D HP: 15-500 Hz / 150 Hz - 5 kHz (x10).
Filters channel E LP: 60 - 120 Hz + subsonic 25 Hz
High level input with auto start Yes
Power consumption (idle) 1 A
Power consumption (max) 90 A
Rec. power cable Minimum 4AWG / 21 mm2
Fuses 3 x 30 A
Dimension (W x D x H) 70 x 437 x 268 mm / 2,92 x 17,2 x 10,55 "
Weight 5 kg / 11 lb
I have the most flexible and versatile 5 channel amp you will be able to find, JL Audio 500/5!!!!
100 x 2 @ 1.5-4 ohm
25 x 2 @ 1.5-4 ohm
250 x [email protected] 1.5-4 ohm
This thing is in awesome shape, near perfect I would say. Let me know!!!!!!
Discussion Starter · #12 ·
Thanks everyone, but I picked something up already. Sorry for the delay.
1 - 12 of 12 Posts
