Installed a new Joying. LR front out to Dayton Audio DSP Channel 1 and 2 in. Chanel 1+2 out from Dayton to input on Rockford amp channel 1+2 in for Tweeters, then out to tweeters from Amp. Channel 3+4 out from Dayton into 3+4 input on Rockford, channel 3+4 out to Mids in doors. I know I hooked everything up right.
I turn on head unit, no problem, but Amps arent turning on. I know amp remote is connected.... nah, you need to go into settings on the Joying and tell it you are running external amps for it to apparently send the signal through the amp remote on wire.
Ok, so now amps have turned on, but NO SOUND. Whats going on. Im thinking it is the dsp, so I simply park Corvette next to truck and plug the mids out on the dsp in my truck into the mids in on the rockford, essentially Im now using the input source from the head unit on my truck. Pow, I have sound. Ok, so it much have been the dsp. So I take the new dsp that I had no sound on and plug it into my truck... boom, it works fine.
Ok, ok... so now Im thinking , wth , do I actually need to go into setting on the joying and tell it to use front LR outs to send the signal into the dsp? So, I take the RCAs coming from the Joying and run it into the dsp im my truck...pow, I have sound.
I have basically isolated the amps, the head unit, the dsp individually from the corvette over to my truck and it all worked, yet when I had them all hooked up together in the Vette, I had no sound. IM done for the day. I need some beers at the local brewery. Back at this crap tomorrow.
Ive never been more frustrated.
