1 - 7 of 7 Posts
Super Moderator
For Sale is a US Amps US-X2 Active Crossover. $50 shipped
I need an external device with a subsonic filter; like a crossover.
Manual here:
http://www.usamps.com/technical/pdf/owners_manual[2001].pdf
The US-X2 is missing the plug and the bolts that hold the plexiglass cover to the metal base. Should be able to make a plug (I will include the connectors I was making) or solder connections directly to the board.
1 input
1 HP crossover (50-500Hz)
1 LP crossover (50-500Hz)
1 output gain control
1 Bass boost control
2way 2-way 2 way two to too
Super Moderator
Re: WTT / WTS - US Amps Crossover US-X2
You can get a plug from WECO or TYCO, dont solder directly to that.
Thanks, look like good options. I was building a plug using desktop computer power connectors. I was not trying to make it look perfect, just as long as it worked properly.
Bump. $45.
This picture is of a different US-Amps crossover; this is how the bolts should look holding on the plastic cover. Probably a dollar or 2 at your home supply store.
Super Moderator
$30 shipped
I guess you all see where this is going. :p
1 - 7 of 7 Posts
