1 - 7 of 7 Posts
I would like to use the Dayton RS 7" and the LPG 26NA in custom door pods in my yukon. I was wondering if one of the dayton xovers from parts express would work and also would that eliminate me from having to have 4 channels? I would be willing to have a custom xover built so that i could run them off a single 100 x 2 amp. where should i have this done at and do you have any other suggestions? Thank u
This is what solen.ca said about getting a x-over:
The recommended X-over for the L18RNX/P08 and the LPG 26NA is a second order @ 3500Hz with a notch filter on the woofer.
Impedance will be 8 ohms.
You can a run a single 2ch amp.
Would this be ok? Also how much power should i send these? would 200 x 2 @ 4 ohms be sufficient? thanks.
Depends on the specs on the speakers in question. Some can be filtered with only a few components, others require more complex networks, like impedance correction, higher order crossoverslopes etc. More components, more cash :)
1 - 7 of 7 Posts
