I am thinking about picking up a DSP next year.
I seen the posts about the mini dsp, and was wondering during how that would compare to Audio Control DM-608 which caught my eye.
I see on the mini dsp there are 4 inputs.
The Audio Control has 6 inputs.
I have front, rear, and sub outputs from the headunit.
So would you select full range on the front and rear on the headunit, and use the mini dsp to cross everything over, and get a signal to the sub?
The mini has better crossover options, the Audio Control only has 12 or 24
The Audio Control has a 30 band eq, where the mini has a 6 band parametric.
But my headunit has an eq also, so an extra 6 would probably be fine.
The mini is quite a bit cheaper then the Audio Control. 250 cheaper.
Any thoughts on how the mini compares to the Audio Control?
