1 - 1 of 1 Posts
I'm planning to mount my Dc Ref's as stealthily as possible, I was planning to put one behind the rear panel on each side of my Bronco, and the third under the back seat. My concern is if I am going to run into issues with cooling.
My plan is to put an exhaust fan in the rear storage pockets on each side and let it draw in cool air through the speaker opening in the front of the panel, drawing air past the amps. I know that the amp has a fan built in, but as you can see in the picture below the external fins on the end will be pretty much even with the lip shown, and only about an inch or so between them and the top of the body. Will the airflow of the fan be enough given the small area on the top?
1 - 1 of 1 Posts
