I'm finally officially listing this amplifier for sale. I had purchased it in anticipation of installing it but had totaled my car before the system made it in.
My new car has significantly less room available, so it makes sense to run with smaller gear.
I have never installed, nor put power to this amp. It does have a few imperfections, from shipping/ handling I'm assuming. I bought it as a b-stock unit. Pictures show the current condition. Any other questions, please feel free to comment or PM me!
$900 shipped & insured within the CONUS
Zapco Z-3KD II
MONO SOUND Q CLASS D BASS AMP
A beefed up power supply. Increased power. New high end audio caps like the SQ amps. New TI low noise op-amps like the SQ amps. Improved tiffany style panel mount RCA connectors. The end plates are now recessed like the LX amps for a cleaner look. The plastic controls have been replaced by the new metal pots and switches.
Power @ 4Ω: 900 watts
Power @ 2Ω: 1800 watts
Power @ 1Ω: 3000 watts
Linked @ 2Ω: 6000 Watts
THD @ Rated Power < 0.05%
Signal to Noise Ratio > 90dB
Damping factor: > 350
Efficiency: 86%
Input Sensitivity .2v to 8v
Dimensions in mm: 190(W) x 62(H) x 620(L) Overall: 190(W) x 62(H) x 657(L)
Rectangle Tableware Wood Flooring Gas
Musical instrument Keyboard Wood Musical instrument accessory Skyscraper
Grille Gas Composite material Electronic device Metal
Grille Rectangle Wood Flooring Floor
Musical instrument Office equipment Wood Composite material Gas
Rectangle Textile Wood Asphalt Road surface
Grille Motor vehicle Hood Automotive design Rectangle
Grille Motor vehicle Font Automotive design Line
Grille Hood Wood Automotive exterior Musical instrument accessory
Grille Wood Hood Automotive exterior Material property
