1 - 2 of 2 Posts
Product Brand & Model: Zed Audio - Minotaur
Condition of all items: Brand New
Total Price: : $625.00 via Paypal
Shipping Terms: :Included in price. Will be shipped via fedex ground.
Additional info: Wont need in my current setup. If you want the 6 channel Leviathan III amplifier in the exact same condition. Please let me know. Never seen power or etc. Brand new amplifier. Let me know if you have any questions. Send PM's for best response.
Specifications:
Rated power is 750 watts into 4 ohm or 1.3Kilowatt into 2 ohm.
Two Minotaurs bridged deliver 1.5Kilowatt into 8 ohm or 2.6 Kilowatt into 4 ohm.
One, two or four input configuration.
Two line outputs, one in phase for parallel operation and one out of phase for bridged operation.
Industry first 48 dB per octave Linkwitz Riley High Pass crossover 10Hz-100Hz
Low Pass 24 dB per octave Linkwitz-Riley crossover 45Hz-230Hz
Phase control variable 0 to 180 degrees.
Five band equalizer with constant Q response set at ISO-frequencies 25 Hz, 31 Hz, 40 Hz, 50 Hz and 63 Hz.
Preamplifier bypass for full range operation.
Level control accommodates input levels up to 8.6v RMS.
Pre-amplifiers utilize a fully isolated power supply for zero ground loops.
Pre-amplifiers drive the main amplifiers in a fully balanced mode.
Class D amplifier utilizes high-speed high current low gate charge MOSFETs.
New low impedance protection using an analog computer.
Fully regulated power supply delivers power independent of battery voltage.
There are a total of seven regulated power supplies.
The power supply utilizes eight 110 amp MOSFETs.
Low ESR 105°C capacitors are used in the power supply.
Very high efficiency owing to the smart power supply.
Tiffany RCA's with Teflon inserts are used for ultimate quality and reliability.
Made in the USA
Please be advised, all buyers and sellers are responsible for performing their own due diligence when considering any financial engagement. We recommend that you:
1 - 2 of 2 Posts
