1 - 12 of 12 Posts
Don't really want to sell but I've had some unexpected expenditures this week.
This is the perfect amp for a set of mids or components. As someone else said - It is the perfect amplifier to go active 2-way (provided you have a sub low pass) because of its ability to high/low pass 50 Hz - 4,200 Hz. Add another amplifer to the line out and BAM you're ACTIVE!
It's in pretty near mint shape except for one bent cooling fin and a missing speaker lead screw (which I am working on replacing). The logo is still there and the amp has almost no scratches/chips besides the bent fin. BTW - the bent fin is on the bottom row and not really visible once mounted. I'm just picky.
This is CLEAN sounding amp. It even sounds better than my PPI art series amps, IMO.
ESX Q75.2
Power (this amp is way underated, btw)
2 x 75 W @ 4 ohms (12V)
2 x 120 W @ 2 ohms (12V)
1 x 240 W @ 4 ohms bridge (12V)
1 x 85 W @ 4 ohms bridge "TRUE MONO" (12V)
1 x 160 W @ 2 ohms bridge "TRUE MONO" (12V)
1 x 230 W @ 1 ohms bridge "TRUE MONO" (12V)
1 x 120 W @ 4 ohms bridge "TRUE MONO/HI V" (12V)
1 x 210 W @ 2 ohms bridge "TRUE MONO/HI V" (12V)
Two amps can be bridged to double the power
Imp Sensitivity
Balanced: 300mV - 18V
Unbalanced: 150mV - 9V
High/Low Pass Crossover
50 Hz - 4.2 KHz @ 12 dB/octave
Dimensions
73 mm x 232 mm x 180 mm (2.87" x 9.13" x 7.08")
I'm looking for $150OBO + shipping
Hahaha... that was me. Good luck with the sale.
1 - 12 of 12 Posts
