Well for the 2nd time since starting my car audio journey I have switched cars before really starting my build.
My new to me car is a 2013 Audi S5. I plan on keeping this one for a while
The faftory audio system is; NON NAV, NON B&O, NON MOST Network,Copper from the Factory HU back to the factory Amp in the trunk, factory tweeters in the dash windshield corners, mid in center of dash, 8" woofers in lower doors, mid of some type and tweeters in the sides for the rear seats, and a "sub" on the rear deck)
I have the following in hand
JL FIX 82 to clean up the Factory Audio Signal
JL TWK 88 for DSP
Raspbery PI feeding into the TWK via digital to play FLAC audio, controlled by 8" tablet (will be on a removable bracket in the dash )
this will feed a JL HP 900/5
I will be forgoing the center channel, and rear channels.
front stage will consist of the following on each side
SB Acoustics SB17NRXC35-4 in place of the 8", mainly due to the shallow mount depth
SEAS Prestige 27TFFNC/G (H1396) in the door sails (this frees up the dash corners for mids if I want to go to a 3 way setup in the future)
IDMAX 10 d2v4, I will try it IB on the rear deck first, if this doesn't work then I will have to play with other ideas.
The S5 is much quieter in side vs the A5 but there is more exhaust noise, so I will need to add some deadening to the trunk for sure.
I will upload some pics of the car.
JL TWK 88 for DSP
