281 - 300 of 666 Posts
I made an adapter or two. This isn't even all of them.
These dash mounts dropped right in. But I've already identified some areas that can be improved - will adjust the model and have them re-printed soon. Fighting the urge to just buy a P1S right now 😏
What are the standard grilles like? Usable with this set up or will you print some to match?
I have an X1 Carbon and I'd like to try printing some mounts with CF reinforced ABS, I think it should hold up to dashboard temps but correct me if you discover otherwise.
Use ASA-CF. It's less toxic and won't fade. Or spend a little extra and get some Priline PC-CF.
owns 2022 Ford Explorer ST
These will be covered with factory grills that have the material in the center of them cut out and the whole thing wrapped with black grill cloth.
I'm just learning about the different FDM filaments myself. These were printed in ASA which from what I read, and found on youtube filament test videos, can withstand the summer heat inside a parked car. It also accepts thread cutting fasteners without cracking from my experience.
@BobTheBirdTurd - What's the advantage of using a -CF type filament in this applications?
ABS/ASA/PC are notorious for warping and shrinking, you need a hot bed, use a brim to increase surface area (on smaller parts), and the chamber temps needs to kept as high as possible to help prevent premature cooling of the part, thereby warping and possibly breaking free from the bed. Even then, there will be some dimensional deviations requiring the tweaking of the profile to compensate to the shrinking. CF will add a little strength to the part, but it's primary benefit is dimensional stability. You get much less shrinking, parts are more stable (closer to desired dimensions), and substantially less warping. I have never had a warped part printed with Priline PC-CF, that includes printing on my old Ender 3 printers that were not in a chamber. It must be kept dry, I run mine directly from the dryer while actively being dried during the entire print. I do the same for ASA, I don't print with ABS as ABS and ASA are pretty much the same except ASA has 10x UV protection and is less toxic. CF filaments also look nice and can easily be sanded and painted.
phone holder and conductor mount in abs… let’s hope it goes right… the enclosure is the spare room and it stays closed for the duration… no draughts and it’s printed ok so far in ABS for the test efforts
fingers crossed with that print time… it’s only 150g of filament so approx £3 if it fails 😂
Couldn’t recall which way up the conductor cable came off so cut two notches lol
Hey guys, I've been dipping my toes into fusion 360 and I have been successful in creating what I've wanted to so far, but I'm trying work with surfaces/form and I'm not sure where to start. Are any of you more skilled members willing to give me a bit of guidance on the side? Anyone willing dm me. I'll certainly throw some funds your way for the effort.
Forms are a pain in the ass. I can work with them a bit, but an expert.
Surfaces aren't too awful and useful for making complex transitions and sweeps easier. Forms seem like magic - no idea how to even start working with them.
Forms are just like poly modeling in other 3D programs. It's like using polys with a Turbosmooth in Max or Smooth in Maya, and frankly, those programs are better at it, but they are not good at modeling to a precise scale or dimension.
My point is, once you get used to them, they are not difficult to understand, but I still use solid and surface modeling in Fusion because that's what it's designed for.
