Ok, so the component set I am lusting after, only because of the bi-amp capable passive crossover is the Sony XS-GS1621c. This is the only way I can think of that you could FULLY and SAFELY control the sound of the tweeters and woofers INDEPENDENTLY in an active setup, with a 4 channel amp, where the front channels are used for the tweeters, and the rear for the front stage midranges. What I wanted to do, is use two sets of identical passive crossovers (I have an extra set from a partial kit) to essentially achieve the same result as the bi-amp crossover in the Sony kit . I took the time to create a diagram below to illustrate what I am talking about. Would this setup work?? *the right side midrange and tweeter crossovers are incorrectly labeled... I am aware of it, please don't dwell on that.
Thanks for looking and any advice you have.
