I have had 3 different Kenwood DVD double DIN style head units in my 09 Chevy Silverado recently and both have experienced alternator whine (rpm related) coming through my mids and tweets. I noticed that all 3 head units can seek a ground connection through the antenna plug. In other words, if I physically cut my head unit BLACK wire, the deck still has full power. Now after hours of searching for the root of my noise source (amp and crossover grounds, rcas close to power wires, etc.) I finaly found that if I disconnected the antenna (BLACK wire still connected ofcourse), the alternator noise goes away. Or atleast gets reduced to nearly non-noticeable amount. Has anyone else experienced this? And if so, were you able to correct the problem and still use your antenna without the noise? Please share your experience and solution. Thank you kindly for any constructive input!
