Amp clipping on >min. gain setting. Is it broken?
1 reading
16K views 10 replies 6 participants last post by  Stoopalini
If you’re inputting the amplifiers max unclipped input signal level…. then any increase in gain with most likely create a clipped output signal. If you’re not at max input voltage and your output clips with a slight gain adjustment… then you probably have an issue with the amplifier. Try switching the amplifiers.
