Some interesting history about servo subs
In 1967, Arnie Nudell, PhD. was at work designing the world's first Q-switched pulsed ruby laser to be used in a laser rangefinder that would measure accurately the distance between an airplane and the ground. A servo-feedback system would then be used to control the inertia navigation system of the airplane for accurate positioning. During his laboratory work, Arnie realized that such a servo system would be able to also accurately control a loudspeaker, hence, the idea of a servo-controlled woofer.
Together with John Ulrich, Arnie designed the servo system and power amplifier to drive a woofer. Arnie called another friend - Gene Czerwinski - to make a special 18-inch woofer with a second winding on the voice coil to produce the feedback signal. The system worked! And the world's first servo-controlled woofer was born.
Together with an electrostatic panel developed by another two aerospace engineers, and a cabinet designed and built by Cary Christie in his garage, the first product was built - the Servo Statik I. This was in 1968, and Infinity was founded. Through the 70's Infinity grew until it was acquired by Harman International.
In the 80's, Arnie launched what was to be the first real high-end loudspeaker with the Infinity Reference Standard - or IRS. It was not originally meant to be a commercial product, but to be a statement of the highest reference standard for sound reproduction. It was the first speaker to use the Electro Magnetic Induction Tweeter - the first ribbon tweeter, and featured a line source of tweeters and midrange ribbons in a dipole configuration. It also had a total of twelve 12-inch woofers controlled by dedicated servo amplifiers. Nevertheless, the IRS proved to be a runaway commercial success. Excepted from;
Genesis Advanced Technologies
John Ulrick’s account of the beginning;
We were supposed to be hard at work designing weapons systems for America - that's Arnie Nudell and me. Arnie and I worked at Litton Guidance & Control Systems in Woodland Hills, near L.A. We did build a weapons system, a laser rangefinder that measures the distance from an airplane to the ground for accurate bombing. We were also audiophiles, if there was such a term at the time. The year was 1967. I am an electronic engineer, Arnie a physicist. At Litton, my job was to design the electronics for the laser rangefinder and Arnie's was to design the world's first Q-switched pulsed ruby laser. This was the laser that supplied the pulse of light that went from the airplane to the "target" and bounced back, used to calculate the distance from the airplane to the target. Part of that system involved a mirror to point the laser beam at the target. I designed a servo-control system, which points the mirror and its switching amplifier. During lab testing of the servo-control system, Arnie noticed that the servo was controlling the mirror at 20Hz, a magic number to any audio person. Arnie had a good idea - why don't we make a servo-controlled woofer? We went across the hall to the Litton engineering library and found a book called Acoustical Engineering by Harry F. Olsen - the first bible of acoustics. The book had a page on Servo Controlled Speakers but no analysis, just a block diagram. We worked together to design the system. Arnie calculated the radiation resistance for the slopes and I designed the servo system and the power amplifier to drive the woofer. Arnie called his friend, Gene Czerwinski, to make a special 18-inch woofer with a second winding to generate the feedback signal. At the time Gene was an engineer at Bendix and making speakers in his garage. Gene later left Bendix to found Cerwin Vega. At this point one could wonder, who is making all these weapons systems? The woofer worked. There were two more aerospace engineers working at nearby Atomics International, Ron and Bob, making electrostatic panels. (The pentagon always said you must value the technology spin off from military research!) What a great combination, electrostatic panels that don't have much bass, coupled with an 18-inch servo-controlled woofer. The system was built and set up in Arnie's living room. Using a Sherwood amplifier to drive the electrostatic panels, the tweaking began. The amount of servo feedback changed. The crossover points moved and moved again.
Arnie and I decided to start a company. You could tell by the name there was no professional help in naming the company. The name was "Nutek" for Nudell Ulrick technology. We began selling a system called the "Servo-Static I" through a local dealer. The local dealer was about a mile from Litton and owned by Dr. Jim Henderson a physicist who you will hear more about later. All of this was still part time with a new guy involved, Cary Christie, a very talented industrial designer making the cabinetry in his garage. Arnie and I put out feelers to raise money and were finally backed by a rep firm that sold me electronic parts at Litton. No sophistication here either; we didn't even have a business plan because we didn't know what one was. A corporation was formed with Arnie and I holding equal interest. Fortunately, when we went to incorporate, the name Nutek was taken. The name Infinity was the third choice on the list, but available. The company name was Infinity, the year 1968. Again Arnie and I demonstrated our management prowess in choosing who was going to be the first president; we used the coin toss method. I was the president the first year and then we alternated for the first several years. What confusion! In August 1968 myself, Arnie and Cary and a couple of other people started full time in a 2,000 sq. ft. building in Chatsworth. Infinity was started. At the start, Infinity had three speakers; the Servo-Static I ($1800), the 2000, a bookshelf with electrostatic tweeters ($276) and the 1000, a 2 way bookshelf speaker. Excerpted from
http://www.spectronav.com/tech2.htm
