Anyone have experience with Rockford Fosgate Power T600-4?
11K views 6 replies 4 participants last post by  thomasluke
Been looking for an amp and this one keeps popping up as a logical choice.
I'll be running a two way active front with HAT plus sub (undecided) through the pioneer deh-80prs.
I was looking for around 100-125 watts a channel and this one just keeps appearing as the most cost effective solution.
If anyone has experience with this amp please do tell. I've had Rockford amps before and they never let me down. Always pretty reliable.
#2 ·
Great amp, used mine active on a set of Focal K2p's and Vifa XT-25's and more than enough power, my birth sheet was around 146wpc. Very clean and detailed, but will definitly draw a lot of amps. I switched out to a pair of PPI p900-4's early this year and even though around the same power, they seen to get a little harsher at louder levels. Great choice for the money.
#3 ·
I use my T600-4 to run my tweeters. It's the Hertz XL components run active through a BitOne. the rear channels are used for rear fill on my 6x9's when i want volume over sq. I also have the T600-2 to run my midwoofers.
This amp was the choice I made, and I think you'd like it as well. Strong power and they are quite durable. A few weeks ago I made a 7hour drive by myself from 8:30-3:30am, so it was loud to keep me awake. The amps got warm, but ran strong the whole time.
#4 ·
That's great to hear their birth sheet reads well over what they are rated for :D
But I wonder if that can be backed up at all? Or if those birth sheet ratings are just a gimmicky way of measuring these amps without compliance. Either way I think that the power should be fine for my needs so long as its hitting the rated amount.
And it's a definite plus to hear that they can take a beating as well. It's surprising they get that much power and keep it fairly cool from what ive heard around from a class A/B.
#5 ·
Trust me, making rated power is not a problem. I used a t400-4 bridged passive at 2ohms for 3 years in my work truck with o problems, so great reliability also.
#7 ·
Because it's just a Rockford. It's not a brand that has an "sq" stigma around it anymore.
Just another sell out.
I'm not saying that this is true or my opinion of the company. Just the reason it doesn't get much play around here.
Go Over to the MSD forum and say one of things that i did above and bet your ass that you will be banned within the hour.
