Hi,
As you can see in my project, I own an AudioControl EQX and 4XS. Those will be used to build a 3-ways + sub setup, but I have a question about them...
Both crossovers work with modules and both have a 'PFM' (AudioControls name for subsonic) module in them. Standard this is set to 30 or 33Hz and off course I want my system to play as low as my subwoofers allow.
Now the problem: the signal going to the subwoofer amplifier passes trough both crossovers, so trough both subsonic filters. Off course I'll use one of them to protect my subwoofer, but a second one would only lower the bottom-end output even more, even if I pick the same frequency or a slightly lower one.
I have 2 possibility's:
- find out on what frequency I have to set both subsonic filters, to become the same effect as 1 subsonic filter at the desired frequency
- disabling one subsonic filter
I prefer disabling 1 subsonic filter, otherwise I'd have to change both modules if I want to change the subsonic frequency. The only way to disable the built in subsonic filter (since there is no other way to disable it) is to set it to a very very low frequency. 0Hz is the lowest 'frequency' I can imagine...
AudioControl crossovers use higher value resistors for lower frequencies and lower value resistors for higher frequencies, so to set the lowest frequency possible, I'd have to use the highest value resistor available...
The highest value resistor I know here on earth is... air, meaning I should just leave the frequency module bank of 1 of the subsonic filters open. (easy
But... Can I do this? Aren't there any limitations to the lowest frequency I can set the subsonic filter at/highest value resistors I can use?
If you use the 4XS as a 2-channel 3-ways filter, there is 1 module inside that isn't used, but the manual says there has to be a module in that bank, but they don't say anything about the PFM...
greetz,
Isabelle
greetz,
Isabelle
