Bass knob
1K views 1 reply 2 participants last post by  CCole
I got an ACM 1.300. Gain is at min but still too much bass. Will a bass knob still reduce volume?
#2 ·
My initial thought is the line level voltage from your source is too high which you probably know. The bass knob should help as it will give you attenuation from zero to max output based on gain. There are some cheap amps that the bass knob adjusts the gain. Really bad idea but this shouldn’t apply to you.
