The download link was posted on the Audiotec-Fischer site... and then quickly removed.
How much of a bump are we talking?I ran another tune today. It works out much better.
QQ: I like the fact that I can use a virtual RTA to fix automation problems of the left side, drivers, and then the right side drivers. However, I really do wish that I knew how to have an RTA on the entire system playing together. To get rid of those unexpected bumps is it possible?
Amy update on ETA?It’s not in the wild yet 👍🏼
No official update other than it’s in the worksAmy update on ETA?
Where does it say you shouldn’t auto eq the sub? I use auto eq on subs…I had chat gpt help me to find information on how to better integrate my subwoofer. Based on information that I have found From helix themselves, specifically their DSP tuning guide, I had no idea that you shouldn’t auto EQ the sub. That you should just auto EQ the rest of the drivers, and focus on phase for the sub as well as leveling the volume of the sub to be within 3 to 6 dB of all of the other drivers playing together. Go figure! I can forgive myself as I am an amateur now that I have the house curved that I like, and it’s clear that it’s hard to do phase with DSP tool, it’s time to give total tuning a call for an updated tune.
I thought it was my mic as when I'm checking highs and mids I have output from 45-60Hz and when using auto eq on the sub it cuts a lot in the section. I just used higher volume and adjusted manually to match closest to the desired curve while analyzing the response in the Helix software. I like it better than what the auto eq did for sub.I had chat gpt help me to find information on how to better integrate my subwoofer. Based on information that I have found From helix themselves, specifically their DSP tuning guide, I had no idea that you shouldn’t auto EQ the sub. That you should just auto EQ the rest of the drivers, and focus on phase for the sub as well as leveling the volume of the sub to be within 3 to 6 dB of all of the other drivers playing together. Go figure! I can forgive myself as I am an amateur now that I have the house curved that I like, and it’s clear that it’s hard to do phase with DSP tool, it’s time to give total tuning a call for an updated tune.
Yes. This is what would happen to me over and over. The volume1 tuning guide says to adjust phase and gain for the sub to acoustically integrate it into system. And only very light EQ if needed. This is different than the other drivers for which it says to eq them.I thought it was my mic as when I'm checking highs and mids I have output from 45-60Hz and when using auto eq on the sub it cuts a lot in the section. I just used higher volume and adjusted manually to match closest to the desired curve while analyzing the response in the Helix software. I like it better than what the auto eq did for sub.I had chat gpt help me to find information on how to better integrate my subwoofer. Based on information that I have found From helix themselves, specifically their DSP tuning guide, I had no idea that you shouldn’t auto EQ the sub. That you should just auto EQ the rest of the drivers, and focus on phase for the sub as well as leveling the volume of the sub to be within 3 to 6 dB of all of the other drivers playing together. Go figure! I can forgive myself as I am an amateur now that I have the house curved that I like, and it’s clear that it’s hard to do phase with DSP tool, it’s time to give total tuning a call for an updated tune.
given the production of the AMI i wonder if phase measurement will be integrated into a future DSP tool update ...And since PC Tool doesn't do phase measurements, you have to use REW or other software that do.
That's an old as guide.Yes. This is what would happen to me over and over. The volume1 tuning guide says to adjust phase and gain for the sub to acoustically integrate it into system. And only very light EQ if needed. This is different than the other drivers for which it says to eq them.
Does this still happen @Raceengineer? I'm getting this even now.I've been getting some random glitches in the past 24 hrs...
Random turning off of channels when in the tool working, channel will be selected as active but sound becomes muted. Button becomes non responsive.
