The download link was posted on the Audiotec-Fischer site... and then quickly removed.
So not sure if you worked this out… when you upgrade from pct5 to pct6 the files existing in the Dsp are saved and converted to a new set of files to be loaded back inOK. I've loaded the new software onto my Helix P-Six Ultimate... no issues.
As mentioned above, I did have to recreate everything from scratch, as the old Version 5 files don't transfer to the new software. However, as @dumdum also mentioned, they are working on this and in subsequent updates, you should be able to import your Version 5 tune file. At this time (for me) this isn't a big deal, as I am about to do a full fresh tune in the vehicle (well... AudioGal is going to do it). For this process, I only had to recreate the Input / Output structure, as well as the basic crossover points.
I'm not sure if my ears are playing tricks on me... but I swear the overall sound is slightly 'crisper' than before. The clarity just sounds a bit sharper. I could be wrong... but that's what I'm hearing in my initial listening experience.
@dumdum is this a figment of my imagination? Or has Audiotec-Fischer done some wizardry to improve the overall sound quality?
Nope… no wizardry… that’s your ears playing tricks sadlyOK. I've loaded the new software onto my Helix P-Six Ultimate... no issues.
OK.Nope… no wizardry… that’s your ears playing tricks sadly
Yes I figured this out, after I had recreated the entire I/O and crossover structure... oh well.when you upgrade from pct5 to pct6 the files existing in the Dsp are saved and converted to a new set of files to be loaded back in
potentially it may be the new feature which nescesitates the change of gain structure, it may be that louder in some channels sounds different incase limits are near and met in some channels post importOK.
But I swear it does sound different... The overall Gain is definitely a bit lower (maybe 3dB lower output).
And I'm certain I'm hearing a bit more 'crispness'. But perhaps the output on the tweeters is higher.
I dunno... I'm just reporting what I'm hearing.
Yes buddy, it’s just a phased release on selected devices for a start, sorry I missed this…Will this trickle down so older devices can eventually use it?
That's great, good to hear. Mine wasn't added until version 4 and they responded to my email stating that they are aware of the issue with my model and there could be an update by the end of the week.I downloaded it, the minute it was released and loaded it onto my P-Six Ultimate. It worked flawlessly right out of the gate.
We are now on Version 4 and it is still working without any issues for me...
@dumdum can assistDo they have a bug reporting tool or do we just send them an email through the contact form on the website?
Fire away and the bug reporting tool… aka me… will feed it back, I can also confirm if it’s something we are aware of as well 👍🏼Do they have a bug reporting tool or do we just send them an email through the contact form on the website?
Cheers bug man!Fire away and the bug reporting tool… aka me… will feed it back, I can also confirm if it’s something we are aware of as well 👍🏼Do they have a bug reporting tool or do we just send them an email through the contact form on the website?
Passed on… they have found the issue and will be fixed on the next release 👍🏼Cheers bug man!
I have the M Four DSP and have lost the ability to mute the output channels. Muting the virtual channels still works but I can't isolate my components
Thanks legend! 👌🏼Passed on… they have found the issue and will be fixed on the next release 👍🏼Cheers bug man!
Hi there dumdum,Fire away and the bug reporting tool… aka me… will feed it back, I can also confirm if it’s something we are aware of as well 👍🏼
Can you email me the file that was saved in .03 and then imported to .05 that exhibits this issue please so I can pass it on, I’ll drop you a message nowHi there dumdum,
I have the P SIX DSP ULTIMATE and the newest .05 version has a scary bug. After loading back the old preset, it will up the gain on the first channel by about 15db. Almost blew my left tweeter. I tried reloading both the software and presets with no success. The .03 version works flawlessly, and I actually think the system sounds a little better on the new software.
Thanks and take care.
