SqNut, you're really frustrating.
Well, it's not by design, if that is of any help
. I respect you and I continue to learn from you. I'm not trying to be a contrarian but I would really like to discuss this topic with you. Just want to clear the context. I know I'll be wiser in some way post this discussion.
12dB cuts or even more are quite common in tuning a car. Of course, if you eschew using an analyzer, then you'd never know this.
Depends on how you're measuring and correcting. If you're measuring at 1/12 or 1/24 and you have control over a thousand pots across the spectrum and the objective is to flatten all measured peaks, then yes one will be cutting 12db or more at quite a few places.
But you don't have to flatten everything you can measure, only that which you're hearing. Ear level measuement in a room will also give combing artifacts. Look at it in a high enough resolution and you will have your 8-10db peaks there as well. But that doesn't seem to bother us. One doesn't feel the need to whip out an eq and start tweaking.
At a resolution of 1/3 oct where one can correct (on most processors) or 1/6 ish which is what we're basically hearing, the situation looks very different. Heck, my bit10 maxes out at +/- 12db and both my ears and measurements tell me that I don't need to cut or boost anything in a drivers pass band by 12db. Beyond the pass band sure I'd cut 20 db if I could.
An analyzer is as common as an rta app on the android, as a very basic tool.
1. Few people can correlate what they hear with the tools. This is what Harman's training attempts to address.
I wish I had access to this tool seven years ago. The ability to correlate what one is hearing with the relevant frequency/range to correct takes time. I tried the tool about 2 years back after ~5 years of tuning by measuring and by ear and one could pick the frequency boosted or cut or be within +/- 1/3 oct 9 times out of 10. If I had the tool earlier I would have learned quicker.
The point is that correlation, can be learned. Either with the tool or by just stumbling along till things start falling in place. Either ways it is not something that one learns in a day or a month or even a year. It is a painfully slow process.
But it can be learned. 80, 160 and 200hz all add extra bloat / fatness / boom to the sound, the three are very different and distinct sounds. If its bloated cut 80, if its fat cut 160 and if its boomy cut ~200.
2. Different pieces of music concentrate energy in different spectra. IF you have a massive peak at 1k, but the music you're using to tune doesn't have any content there, you won't find anything to fix. Then, when you play a piece with a saxophone or Amy Winehouse singing, you'll reach for the EQ and turn down 1k too much because there's more info concentrated at 1k than in lots of other music.
When you have the right balance in the response it doesn't make a difference if you're listening to Amy or Immogen Heap, they will both sound accurate. Tuning is done across a wide spectrum of music. Acoustic balance across the 10 octaves makes everything fall in place. If one has a huge peak at 1khz, one will hear the sound thin out. Too little of 1khz and the sound is dead with no dynamics, too much and the sound will thin out and sound like a cheap radio.
Think about this one. Let's say you were asked to turn the volume up by 3dB. The first time, you had to choose the 3dB using your ears. The second time, you could use an SPL meter. Which one would be more accurate?
Sure measuring is easier and more accurate. But the whole point of tuning by ear is that the measurement devices that count are those which are fixed to the sides of our head. The ear will tell you if a cut of X is too much, too little or just right. The ears are the measuring device. Assuming the ability to correlate is in place.
I'm just trying to be helpful here, as usual.
Now you're embarrassing me
One has to start off by measuring, get the timing right, get the L/R balanced, level match, then measure and dial in the appropriate house curve. What next? Is that the best the car can sound? Do we now need to measure 50 additional things.
At the end of the day it comes down to using timing and response and the ears to go beyond that. Measurements will take you so far, but beyond that you have to go by what you're hearing. You will do some basic measurements even when you're tuning by ear, just to make you haven't thrown something out of whack. But if you have, chances are your ears will tell you that even before you pull out the mic and laptop.
Arun
