I have a match pp82 dsp for 250 - that’s 8x55w or 2 pre outs for a sub instead of the last two amp channels. It’s runs off the helix dsp software and is probably a more reliable option. Otherwise I’d go for a dsp.3 or arc ps8 and dedicated amps. Rainbow stuff looks suspicious to me. Ps8-50 isn’t half bad either.
the stereo integrity mid and tweeter are not good. Too much distortion caused by cone breakup, and they aren’t flexible with the crossover. Ideally you want a mid that can go to 300hz or below.
super budget gems:
SB acoustics sb21rdcn. This is a very small tweeter with super low distortion, much better than the m25. $110/pr
scanspeak 10f 8414g10
low distortion, plays all the way to to 20khz, can cross as low as 250-300hz. No cone breakup or harshness. $180/pr on sale right now
peerless hds 6.5 - multiple models, all are good. 120/pr
Stereo integrity lied about the tm65 xmax so these have just as much but more finesse.
Not certain I agree with either assertion on the TM65 or the mids, not a month goes by where somone that is selling an extra pair jumps on them when they are available.
Needing a mid to go to 300Hz, bit of a stretch, and absolutely build specific, enclosure-specific when you start to get in that frequency range, size-dependent too.
I'm going to be pushing close to 150 watts to my mids, at 250-300, better be in a good quality stuffed .5 to 2l sealed pod or box, or you'll likely be getting a buzz that is definitely not what I would consider a pleasant high at all.
The scans are nice, but again, they require a decent sealed or vented enclosure to play between 70 and 130 Hz, respectively.
Now the Scanspeak Discovery 10F/4424G, that's about $130.00 each, and they are a pretty killer midrange/midwoofer drivers.
The Scans are not going to handle much power tuned that low, either sealed, vented, or IB, they won't handle much more, if any more than 15-20 watts, maybe 30 watts peak.
The other consideration is the breakup. They do go low, but the trade-off is the other end. The
10F/8414G-10 will only really play well up to around 3k before significant breakup and off-axis issues start to occur.
The 10F/4424G is even worse. Goes a bit lower but has an effective usable range to about 2.2k+; breakup and off-axis response suffer a bit.
Not terribly, but these are designed primarily for a controlled home environment, not so much for cars, IMHO.
I'd not want to use them any higher than 3.5- 4k, which is fine, just not sure how that would do.
Now the SB acoustic line has some very good, reasonably priced drivers, such as the SB Acoustics SB12CACS25-08 4"ceramic 4" woofers, or the SB Acoustics SB12MNRX2-25-04, excellent for the money for sure.
Even so, they want an enclosure; most of these are not intended for IB use and they will suffer as a result.
Not trying to shiz on anyone's faves here, but the Si mid is much more geared to automobile use/installations than any of the afore-mentioned drivers.
It's going to play louder, take more power, and play effectively from 300/24LR to almost 6k, that's a pretty impressive driver.
And the Karma Mobile Audio: Aspect 3 - 3 Inch, at $199 a pair, may play well from 150 hz in a .02 cu ft enclosure, maybe a bit higher bottom end in an IB configuration, and is clean and clear to 6k, again, designed for use in a car, it does make a difference.
What sayeth you
@RickWilson ?
My unrequested $0.02.
