Can someone please link me to an external sound card that will enable me to do time alignment with REW. The M-transit audio interface is no longer available. I will be using the Dayton Audio UMM6 USB microphone. TIA
For a 2 way start with the sub and mid crossed ~60hz Put the sub on the steepest slope you have and use some foam or diy bracing to cure the buzzing at 60-90, deaden the door some more if you have to or mount the driver on a 3/4" mdf ring adapter. Start by crossing the mids and tweets ~3khz, 4th order slopes all round. Make sure the timing is right between the sub and mid and mid to tweet.Now, what are some best methods for tuning the EQ for a front 2way running 3SIXTY.3 ?
A bit tongue in cheek, but I am a bit new to sound frequency measures translating to liking what I hear. I know what sounds good, but I'm new to the translation of that on a DSP like the 3Sixty3.
I remember subjectively tuning a 10 or more, maybe 16 band EQ on a piece of hardware, and I would do it just for the sake of that track sounding better, but not as a preset choice of 4 to be pretty much perm in a car once set. I have all the sound files and sweeps of Hz....
I don't really know what to adjust about those test sounds. Its not like I will tune to make those test sound to sound better, no, I know thats not what they are for.
So I used them to normalize, and get a flat signal. Also helped to get some "theoretical" cross over points. I say theoretical as MB Quart QSD 6.5" is able to play 35-280Hz, but it is factory crossed HP with the passive crossover at 240Hz. But you hear people cross them off at 70Hz. I tried the lower Hz noise tests at around 70Hz, but found them to cause more vibrations(my door is fully deadened) up until 90Hz. So, maybe thats better?
Same with the tweeters. They are factory at 2400Hz. I have heard people set their MBQ at 3500/12db, 2400/24, 4000/12db, etc. I have also heard other tweeters xover at 800Hz. So again...a super wide range to play with....where does one start to lower the variables, and then edge out if need be, or if it makes improvements?
Phil, what do you mean by "low audibles"? If you're referring to the presence of low frequency information that is showing up on the RTA trace that you can't really hear, kinda like low freq. noise, then this is just a phenomenon that is part of the reality of acoustic measurements. There is always low freq noise all around us that we don't really, consciously "hear", but it's there. That will not be taken out of your measurements by performing a soundcard calibration. A soundcard calibration is nothing more than compensating for the soundcard's deviation in its own freq. response. It in now way lessens the amount of low freq. noise picked up and ultimitely put into your measurement.I'd like to do this so I don't have all these low audibles the mic picks up without the cal.
[/URL]
