how much weight can a door take?
18K views 23 replies 15 participants last post by  cvjoint
I see alot of guys on here using pounds and pounds of deadening in their doors and was wondering what you all think is too much for the door hinge to handle? is there a weight limit or something. I figure once you put the speaker and the door panel back on then it can get pretty heavy.
Thanks for your imput here :cool:
ALSO ***
is heavier deadener a better choice than lighter deadener? im talking about the dynamat type of stuff that most people use. I kind of goes with my first concern with all the weight on the door, so. :cool:
#2 ·
I am gonna say less than 20 pounds of material to prevent door sag.
evidence: honda civic car door, 9 square feet of damplifier pro, 62 square feet of raammat, and a neodymium 6" speaker with requisite MDF baffle and minor weight added after causes door sag.
remove 20-25 square feet of raammat and the door no longer sags.
the math tells me approximately 20 pounds is the limit, maybe 18-ish.
your car may be different. A big 'ol honkin american-made truck door can probably take more weight than my wimpy civic door.
#9 ·
Most car door hinges are pretty damn tough, for instance, my neighbor is an idiot lol.... but seriously, he owns an eclipse and he can actually sit with his legs through the window opening on his cars door wide open. Now he only weighs 150 probably, but still, that's pretty good. I've never tried on my car, well, because I'm not a douchebag willing to break my hinges, but it can probably be done!
#11 ·
that is really what i'm asking about so thanks for pointing that out. Im thinking that too much weight overtime will cause that lock alignment to get off and therefore screw the door up. And yes I do understand it largely depends on the car, but how will I really know, you know. I don't want to run into probs and then have to take it out cause that could be a *****.
So you guys are saying like 20 lbs is the safe upper limit?
#12 ·
Another thing to remember is to keep your door hinges oiled about 4 times a year I put some 3in1 oil all over the pins and Lithium grease on the door latch (the part that clamps on the U bar)Wayne
#13 ·
Quick little note here guys;
All materials have a certain amount of fatigue, even metal over time fatigues and the streght properties change. This means that even factory stock doors will sag and give over time. Hence it pays to have you door lubed, (as mentioned); but its also worth while to have them re-hung. Any competent smash repair shop or panel-beater should know how to hang a door. Just about every single car has some allowment for re-adjustment built into the hinges, take advatange of this and have your doors done. It about 1.5hours total work to do 2 doors properly. This is a trick I learnt from my racing-car background. (helps chassis load, ridigity and consistancy).
#22 ·
Wow wow now im really worried because im going to put 8 inch midbass drivers in my doors. :(
Don't be. Those people saying they put in a few pounds of stuff and had problems had door hinge wear to begin with and perhaps they just didn't know it. Either that or they are driving very poorly designed cars. Door hinges tend wear out and let doors sag over time, particularly 2 door cars, but 4 doors can do it too.
#24 ·
I just tested mine. My doors showed no sag whatsover. I lifted them until I could see the chasis lift and there was no play. That's on a 9 year old Honda Accord with two massive doors, 4 layers of dynamat extreme, holding 10 inch woofers from Seas, in custom made 60lb/each doors. Before I had an 8 and a 7 in there. I even forced my doors to close while the gasketing tape and fiberglass adjusted a bit.
