Kenwood dmx8020dabs turning off / on!
8.8K views 5 replies 2 participants last post by  bbfoto
Help!
Had a new kenwood dmx8020dabs fitted professionally into my 2008 mercedes ml. All seemed well and I paid and left. About 1/2 hr into my home bound journey the headunit screen went black, music still on ....then the screen came back on. 30 secs later screen and music went off then came back on ....then it all went off and stated again. This happened several times til I had a screen message telling me to stop the car, switch ignition off and on. Obviously I returned straight back to the fitter who wired a power check up and we went for a drive. Toward the end of the drive it happened so he saw this. He thought it may be the aftermarket facia fitting kit ( I have Harmon Kardon logic 7 so this has a MOST module etc in it ) so a new one was fitted the following day. Went for a drive and it seemed ok but about 40 mins the same thing happened where it would turn off and on etc. I left it several hours and tried again but now the head unit will only stay on for a few seconds before turning off and back on. Power to the unit has been checked and is constant so we don't see this as an issue.
Is it possible my brand new unit has an issue or could my Harmon system be causing my headunit to do this? If it were my car set up surely it would have manifested immediately when 1st fitted and not worked for so long then started playing up?
I'm concerned if I return it for warranty exchange, that my Harmon set up may have damaged the head unit and fitting a replacement eventually the same will happen to that unit too.
Be interested to get some feed back what you think and if it maybe I just had a duff headunit. Has anyone experienced this problem with Kenwood before????
Thanks in advance
#2 · (Edited)
The fact that the SCREEN went black or blank is a red flag to me that the HEAD UNIT itself is Faulty. Even if the Audio part of the head unit was wired wrong, I've never experienced a Blank Screen or intermittent display, UNLESS the power wiring (-) and (+) were done erroneously/inadequately.
I would make sure that they are NOT using the (-) Ground wire from the OEM HARNESS to the Head Unit's (-) Ground wire or for the MOST adapter's (-). They should run a separate (-) Ground from the chassis or direct to battery for both.
That head unit has a 15-AMP FUSE so it will need at least a solid 15-amp (+) 12v switched ACC power connection which the OEM stereo harness probably cannot supply (most are around 5-10 amps MAX). This means that the (-) Ground must also be capable of handling 15-Amps, and most OEM harnesses will Not handle that much IME.
They also may be trying to power the (+) power input for the MOST adapter by using the Head Unit's "Remote Turn-On" (+) wire, which is only for low current to operate a small turn-on relay in an aftermarket amplifier, and it will NOT power the MOST adapter adequately.
When you connect an aftermarket MOST adapter, you also need to make sure that any interrupted optical connection or optical "T" connections still complete the entire MOST loop throughout the vehicle. The adapter's MOST connection has to be a Pass-Through, you can't leave any of the OEM Most connectors disconnected, they must all be connected in a loop.
But to me, it seems like a faulty Head Unit. OR incorrect/insufficient (+) & (-) power wiring to the Head Unit and/or MOST adapter.
The power connections they made might not have enough current (amperage capacity), which would allow the head unit to work for a little while until it over-heats due to under-current/lack of power and then shuts off due to that low power state and from thermal overheating. Unfortunately you can't put a CD disc in the unit and eject it after this happens to see if it is super hot. It shouldn't be.
Are they using a MOST adapter like this one?....
Go to Peter's PSsound Facebook page or Instagram and send him a message. He's in the UK and works on a lot of BMW & Mercedes and would most likely know the probable causes. He's a busy guy so, don't expect an answer right away.
#3 ·
bbfoto.....brilliant reply and thank you for taking the time.
My installer is convinced its a power issue although he thinks its to a different module ( does CAN mean anything to you? Sure he mentioned this! ) ....he believes a direct power from the ignition supply would suffice however it would bypass this module meaning I'd loose the minimal steering wheel controls . ..not an issue if it worked!
The MOST module is the same as you show ...as a reference the kit I've used is from a UK company called Connect2 and the part is CTSMC008.2 specifically designed for my vehicle with harmon kardon fibre optic.
I've had a reply from someone saying it is probably a speaker issue in that Harmon Kardon usually have 2 ohm speakers where as most are 4. He says the headunit has a thermal relay and this is kicking in causing my issue .....I haven't a clue if he's right but he mentions being a kenwood installer for 24+ years!
My only worry is most folk I talk to who install etc, they have never had this issue with a kenwood headunit making me wonder if its my set up causing the issue. I can only hope it hasn't damaged the head unit as its currently on its way back for a warranty change. If I get a new unit and my car causes that to do the same im sure the selling company won't exchange ....
I'll send an email to the guy here in the uk.
Thanks again ...
#4 ·
Ahhh...you didn't mention changing the OEM speakers for new aftermarket speakers. Yes, I believe the OEM speakers are 2-Ohm (except for the tweeters), so if the aftermarket speakers are 4-ohm this might be affecting the OEM H-K amp, but I doubt it. A 4-ohm load is easier to power, though you would typically get just half of the wattage from it to the speakers (slightly less volume).
And that shouldn't affect how the Head Unit was acting. Hopefully it was just a bad head unit.
But again, the shop needs to MAKE SURE that the switched ACC circuit they are tapping into will supply at least 15-amps on both the (+) & (-) to the head unit.
They may need to use that switched ACC circuit to trigger a Turn-On Relay, and the relay would then be wired directly to positive (+) and (-) from the battery to supply the head unit with power. That circuit (the + power wire) should be protected by a 15-amp in-line fuse near the battery.
Most modern vehicles are Either CAN-bus (copper wire) OR MOST-bus (digital fiber optical). AFAIK, you will never have both types of communication buses in the same vehicle.
#5 ·
Lol! No you've misunderstood me, they are the factory speakers ....ive changed nothing but the head unit.
My fitter thinks its a power issue ....Im sure your info re a relay would be the best bet...
Headunit arrived back at the shop this afternoon so will see what they think!
I'm worried now about plugging a new one in incase its my car causing the headunits problems!!
#6 ·
Yup, I was confused about the speakers with what you wrote in the previous post. 😊
"Your System" is a OEM factory system. YOU are not responsible if the Kenwood shop/installer that sells you the head unit installs it wrong and causes an issue. The shop should be responsible if they cause any issues when installing the system. You touched nothing. If it happens again with the second head unit, I would demand another replacement and then take it to a different shop to have it installed. :p
Good luck!
