Modeling speaker grills?
2.7K views 7 replies 6 participants last post by  Mike Bober
Hopefully im posting this in the right place.
Now that i finally have access to a 3D printer in one of the labs at my campus, i want to try and get some grills made. I honestly dont know where to start.
The speakers in question are scanspeaks 10f/4424g and dayton titanic 10" subs. For sure i can print the scanspeak, but there printer might not be large enough for the dayton grills.
I have autocad, but little experience with it, but ill definitely use any program yall think i should.
Also, what material should i be using for my speaker grill?
This should be the last time i do this, so i really dont care about becoming an expert in designing this stuff, i just want to have some grills made and be done with it.
Thanks
#3 ·
3D printed parts tend to be brittle and depending on the plastic used can deteriorate over time. It might work fine for the 10f grill, but isn't going to be strong enough to protect a sub woofer from something sliding around in the trunk of a car.
As far as what to use to model the parts, for free software try SketchUp and see if it will output the kind of files the printer needs.
There also should be computers available for use on campus that have software to create models on. Depending on which application the school teaches they probably will have one of either SolidWorks, AutoDesk Inventor, or ProEngineer.
Best and hardest to learn seem mutually exclusive. Fact is, AutoCAD is used very little for 3D these days.
#7 ·
Solidworks is a great program IMO and I would recommend that you use ABS filament over HIPS or PLA...
An industry first "3D Printed Grille Press Box" from a training I attended a while back.
Finished product.
I know you are trying to print the grills themselves, but I'm curious why? Most 3D printers do not print a "finished" product and you will have to do more work to get it to be aesthetically pleasing. Unless you are going for something really dimensional, or a grill pattern that isn't available, I wouldn't print the grill itself. Just my .02-
