New HU...4v or 5v pre outs....
20K views 9 replies 10 participants last post by  mrexcitement
Am I going to notice anything huge regarding 4v or 5v pre outs? I realize 5v is better but for most folks with a simple 2way/sub system...am I missing much? Thanks
#3 ·
I think it really comes down to what your other equipment accepts, and you can always turn down the 5 volt output if need be, but 4 volts is probably enough. Just get what you like.
#4 ·
So is the theory behind this have to do with maximizing the source signal’s volts because they are cleaner than the output signal - which would require a small bit more of amplified gain to make up for the unused volts? Do input volts not have a significant noise floor or something?
#6 ·
Higher voltage increases the signal to noise ratio. The noise that the cables pick up is a certain fixed level, so if you can have a higher voltage level, the noise will be a smaller fraction of the signal. You’ll be gaining up that voltage to a higher voltage to your speakers, and the noise will receive the same gain.
#7 ·
Keep in mind, a 5v headunit is not outputting 5v unless you are cranking the HU to the max. You will never listen to 5v output. IOW, its a non issue.
#8 ·
While I agree with this, it's worth noting that the whole volume range will be 25% higher voltage with a 5v output than a 4v. To that end, a 5v output has significantly better signal to noise at lower volume.
