Old school cassette deck into modern screen
3.8K views 12 replies 3 participants last post by  Ge0
Hi. Just bought home cassette deck seek to play cassettes in Chevy avalanche 2003. I'm reviewing a new double din screen head unit boss bv745b (has aux in audio ) , ill use mainly for mp3 smartphone to Bluetooth but want cassette also. I see some old school used cassette decks for sale.
What are my connection options for the cassette deck ?
Can I get a cassette deck with audio out 3.5mm to go into aux in on screen ?
I am currently not planning on front or rear seperate amps, ill use the screen built in amp to drive speakers plus 1x pre.out to sub amp and sub.
The screen does have 3x pre amp out for front , rear , sub amps. . Did the old casette decks have line out and could I install the 3 amps to screen and have a A/B switch to flip from screen to have casette deck drive the amps?
#2 ·
Why exactly do you want the tape player?? Yes you can use the rca out of a tape player and go into the mini jack on the hu but once again why! Where are you planning on putting a full size tape deck in the car and how are you going to power it, or use it while you’re driving? If you are dead set on using tapes see if you can find a walkman.
#3 ·
Thanks. So om seeking a car cassette deck, not a full size home deck . I enjoy playing records and cassettes, I know it's crazy !. My question really is what kind of outputs were commonly available on the old school car cassette decks . Obviously there is speaker level out, but I'm unclear if decks of that era had line out or pre-out as well. I do see a walkman with both headphone out and a seperate line out , so that would work in HU aux in. I found another HU with proper L and R rca line in instead of aux in. The walkman is expensive as it was a high model in its day.
I could use a line level converter to reduce tape deck speaker level to line level.
I'd rather find a car tape deck , like the walkman, that either had line out, into HU line in, or pre-out , straight onto to power amplifier.
#8 ·
I would be very concerned about tensioner wheel and belt dry rot. The rubber will be at least 25 years old. I would not want to put one of my valuable cassette tapes into an old unit and risk the tape getting chewed up.
With that said, I haven't listened to a cassette in over 25 years. I check on mine about 10 years ago and the tape had fused to itself from sitting dormant for so long.
#5 ·
Sorry I must have been confused by what you we’re trying to accomplish earlier.
This might work for what you’re doing -
Looks like you can charge it and get playback through the headphone output and use that to feed the HU.
Hope it helps besides that all I’ve found was a cheesy $200 dedicated Tape Hu, I guess it depends on how often you plan on using it.
#6 ·
#10 ·
Ge0 - Did your mom at least give you the $8 she sold it for?? I’m sure someone appreciated your B & O turntable as well.
#11 ·
I’ve always like nad stuff as well, being a psb dealer back in the day you we’re forced to pick up nad. They had some reliability issues for awhile but the stuff that held up was really good for money.
