Hello all,
I was wanting to get some recommendations on a new mid range driver for a three way set up. I plan on mounting these drivers on the a pillar with the tweeter above them. I have the peerless SLS 6.5 inch mid bass drivers that will be mounted in the door and the vifa ring radiators tweeters from the alpine type x set.
I like to listen to my music rather loudly most of the time and I have a 12w7 so i need some mids that can keep up volume wise. They will be powered from two channels of a JL 300/4. I have a pxa h700 so eq and crossover points should not be an issue. Would prefer something that is not super deep for mounting issues.
I was looking at some drivers at part-express. These tang bands:
Tang Band W4-1337SD 4" Titanium Driver | Parts-Express.com
or the bamboo cones
Tang Band W4-1320SJ 4" Bamboo Cone Driver | Parts-Express.com
or these daytons which are 4 ohm
Dayton RS100T-8 4" Reference Woofer Truncated Frame | Parts-Express.com
Or are there others i should be looking at? Most of these are 8ohm which would mean i would only have about 38watts to push them. Will they still play loud enough to keep up with the rest of my system?
or the bamboo cones
