Sorry if this seems a little silly or amateurish but I'm trying to pay it my amp board to include my new to me Helix processor. I already have short RCA I'd like to reuse. In order to do that i have to get creative with my power and ground wiring. The fuse block i have had both power and ground in one relatively compact unit. I identified in the pictures below the 2 different routing options I'm thinking about and also identified the gauge size of the terminals on the distro block. Would or be safe to run short 0 ga to the audio control amp straight from the block? I'd be running the RCA above it but perpendicular to each other. Or am i better off going the long way around the rear edge of the amp, the RCA's will still be in relatively close proximity.
Ok a side note, the A.C. amp has 0 ga connections, should i take advantage of that and run the short 0 ga or make it a little easier using 4 ga? I have to use 4ga anyways to the pioneer mono block as it only takes 4 ga.
Sent from my HD1905 using Tapatalk
