A single 10" in the rear deck can provide satisfaction. Not understanding some with this if it isn't large or multiples in IB then it's going to suck theory. I say much regurgitation.
Given the right sub is chosen, improvements over stock are most likely. As stated earlier, in my sedan there is provision for a single 8. The stock Nakamichi system had good tonality, but poor output due to driver & amp limitation. The changer also died so that became a good excuse to put a cd/usb deck in the dash, add an amp, and upgrade at the least the sub. First go round was adding a deck & amp (XD700/5) to stock drivers. The door drivers handle it pretty decently with decent gain on output. The sub though very smooth and excellent extension, just couldn't maintain the levels I wanted without overexcursion. Enter an ARC8 (ID8). Good, but wasn't quite there. Tried different coil configurations and decided to try a different sub. Enter the BA sub. Great tonality and power handling. Can easily outdo the doors. So next upgrades are adding the DSP changing the door drivers which all are on hand.
Moral of the story is...... upgrading performance without augmenting the hell out of the vehicle is very realizable with the right gear. Plenty of 10" drivers on the market that can do nicely compared to a single 8" and probably better than that Infinity with it's lackluster xmax of 7.7mm. Not sure what the problem is here other than finding the right one. And for the record.... Fs of the sub isn't entirely detrimental. Subs can & do play below Fs as long as it isn't some ungodly high number. 30hz in a vehicle added with cabin gain isn't a problem.
