Safe voltage drop???
21K views 19 replies 7 participants last post by  Shadowmarx
What would be considered a safe voltage drop for a Daily driven vehicle?
Safe as in for the electrical of the vehicle the amps and speakers.
#3 ·
If i get 3% I'm good...
Well until I can upgrade my Alt.
I'm used to not get'n below 13.5 with headlights and AC on...
Couple new toys and bam I'm see'n 12.9/12.8
My Batt. sets at rest @ those numbers.
This is with a 150 amp Alt.
Sears platinum Batt.
1/0 power and earth wire... (big three)
I still dont like those numbers.
And See a 300-350 amp Alt. in my future.
I did look it up and just couldn't find anything with a clear definite answer..
If someone has a link to some good info, please share...
Thank you Sir...
#15 · (Edited)
I
That 3 percent figure is from the NEC -national electric code book. Hardcover. Cost about 150.00 bucks. Its was in the backsection under motor homes/ wiring , engies, charging systems , specifing examples from light duty trucks. That's the only source I ever found. Its only on a few pages. The nec never covers much in low volt. The publishers never post links either because its s professional manual, only citing the articles to the code..I wish they would or I would send a link to you. I asked s question like yours at a seminar one time.I was told Its all manufacture specific to the auto they build. Push came to shove and the big 3 us manufactures gave the NEC info which is not much. I don't think there is any published professional electrical code book other than the NEC with the info. It appears to be general guideline at best to avoid total electric failure in mobile charging systems. There has been some concerns about including more low volt specific Info in the NEC . I'm sure in the next few years we will all see the aftermarket audio car audio incorporated into a professional code book and regulated, I.e. National code, Like the NEC It only takes one lobbieist .then again. China would be pushed right out of the market. A good thing.
#4 ·
#6 ·
if you're pulling more amps than your alternator produces, why would an extra battery help? it's just more drain on the alternator and eventually that battery will drain out too and you're back to square one.
save your money and get a new alternator
#14 ·
I thought this was settled by the collective masses.
Mark, want to be the ring master in the center ring of the circus? I'll take the one on the left with the clowns if someone else wants to take the one on the right with the elephants.
