"Setting the amplifier gain higher makes the amplifier work harder"
I hear this statement all the time and I'm tired of not knowing for a fact if this is true or false. Usually it goes like this in a discussion: "You want the strongest input voltage for the amp so you can set the gain lower, and this makes the amp not have to work as hard."
The way I understand it is the gain is merely an adjustment to get the amplifier on the same level as the input voltage to avoid clipping. A properly set gain will have the amplifier operating as intended, regardless of how far the knob is twisted left or right.
Am I missing something here?
