Skar Audio Subwoofer Thiele/small parameters not matching manufacturer specs....but are they close??
1 reading
3.6K views 11 replies 6 participants last post by  96jimmyslt
Hi, hoping someone here will know if the results of my Dayton Audio Dats (v2) test of Skar's VD8-V4 subwoofer are 'within normal ranges.'
I tried to call Skar Audio, but their 'customer service' phone number (888-501-7527) has a voicemail that says they aren't helping people 'temporarily.' I reached out to them via email with my test results asking the same question, and they said to just use their stock parameters to build an enclosure. So I emailed Kevin Schlenker, their CEO (Kevin@skaraudio.com) asking him to forward the question to someone who would help. So far nothing......
The DATS test was performed following the requirements of calibrating the software and warming up (played it for 20 minutes) the subwoofer. The results are attached, along with the manufacturer specs.
I'm not an audio specialist so I don't know if these results are 'close' to what Skar Audio claims. Just looking for an opinion on the parameters, I don't need suggestions on buying a different subwoofer, etc. Thank you.
#5 ·
Now I'm really confused, Skar Audio just wrote back saying.....
Hi there,
I apologize for any confusion. Yes, these are within the range of these specifications and typically what we have found to be the best results.
We appreciate your support!
Regards,
Josh T.
Skar Audio Customer Support
#8 ·
I ran the test again, using a different computer and the results are pretty similar to the first test....the speaker wasn't 'warmed up' which may be some of the difference. Note that Vas on the first is in feet on the most recent one it's in liters. I pulled specs from LoudspeakerDatabase as well...
#12 ·
This is why nobody on the spl forums for the last 10 years would touch skar.
I think he worked at sundown then left and copied the design/used same buildhouse with cheaper parts.
Sell it...go with sundown...etc.
