Typical volume(L/cu ft) in a compact car door?
12K views 7 replies 4 participants last post by  Oliver
...Tried a few searches to no avail.
Short of trying to fill my door with shipping peanuts, what are you guys punching in as a base number when plotting a sealed enclosure representing door airspace in WinISD ? I'm plotting a few 8"ers and want to see what to expect.
I'm thinking around 1.5 cu/ft (or 42L) for a typical compact car door (of course they vary, but as a starting point average). Would you say that is a bit too generous, or pretty close ?
By compact car, I mean along the lines of Civic's/Lancers/Sentra's etc...
Thanks fellas.
#2 ·
Pretty close from what I understand.
One of the heavy hitters here once told me to model somewhere between 1cft. and 3cft. to simulate a leaky car door. I know... It's a broad range, but it shows you are on the right track.
#3 ·
A car door is not going to act the same as an actual sealed box. It's better just to think of it as IB, therefore I'd use a larger amount like over 1.5 ft3 to try an simulate what's going to happen. Also since they will be used as mid bass I presume, I'm not exactly sure what you want to model.
#4 ·
Thanks for the confirmation.
Im trying to figure out what the low end curve is going to look like for a few different potential 8's crossed at about 250hz and down... (-3db point, etc)
#7 ·
In a hypothectical or ideal setting they will show hypothectical or ideal results ;)
I n reality , stick it where you will [ you are going to anyhow ], and hope that it sounds good ;)
As power becomes a factor [ size of piston length of stroke ], all sorts of unplanned things will happen ;)
Do you know your car door inside and out ? [ will the backpressure escape through the weep holes and the window seals ? ]
Here try this ;) take a panel off of your subwoofer,[ front , side back, etc.., ], now crank it just like you normally do [ can you hear how it sounds different with no acoustic spring ?
Can you hear it bottoming out ?[ search for threads about midbasses ;) ]
example: my speaker is rated for x amount of power, "weird", it makes funny sounds way before that :p...
#8 ·
Ideally plot a frequency response you relly like [ totally flat no peaks no dips :) ], then look at the size it says for that curve.
Now here is where your eye will help , no the difference between a size 6 or 8 and a size 14 or 18 ?
If you feel no compulsion to look twice [ she is the size your door will need to be to match that flat frequency response you modelled ;) ].
